Speed sensor issues
Cisco
North Carolina
I've changed both speed sensors on the transmission and the one on the differential and the speedometer still dosent work. HELP!!
renegade 04
Albany New York
Does you odometer work? If your odometer works, then it could be that your speedometer stepper motor has died.
teeje
Toledo
Use the cluster test. With the key OFF hold the trip button then turn the key to ON then let go of the trip button
