rigid
Speedometer started jumping around the other day and then quit . brake light and ABS light are on . Code reader is P500 . I found where the brake cable had been rubbing and thought I found the problem .. No broken wires visible . Took wrap off all the way to the top of the loom . No help around to run key so I took a chance and just bought the sensor for $15 and replaced it . I lost . didn't fix anything after test drive . Cruise light comes on , but does not work and did before . can;t find any fuses with a problem . any ideas ?
thank you
thank you
