Hannibal
Hello everyone.
I have a stock 2WD 2003 Liberty that is in need of new front struts and also lower inner control arm bushings. These bushings are the ones that sit at the bottom of the clevis.
I'm going to throw in a set of Monroe complete strut assemblies. I figure that since I'm already there I may as well change out the bushings.
My questions are:
1) Do I need to compress the old and/or new struts?
2) Are the clevis bolts under extreme tension/load? Should I compress the springs before removing the clevis bolts? (stock setup)
3) Is there any special trick to installing/removing the inner control arm bushings? I plan on using stock MOPAR bushings.
4) What really needs to be removed on the 2WD Liberty in order to replace the struts? So far it looks like on the 2WD all I have to do is set the brakecalipers aside and possibly remove the upper control arm from the knuckle.
5) Can anyone verify that the torque specs for the front suspension on this wiki page are correct?
https://en.wikibooks.org/wiki/Jeep_L...6_Socket_Sizes
I've looked at several how-to threads on this site but they have conflicting info. Rather than try to hash that out, I figured that I would ask if anyone here has changed out the front struts and lower inner control arm bushings on a 2WD Liberty or if you can help me answer the questions above.
Thank you in advance for any assistance, youtube links, etc.
My questions are:
