'04 6 cyl Jeep Liberty with around 80K miles.
Two days ago suddenly a rattle started, though it kind of comes and goes. After getting an oil change, the Jiffy Lube tech (excuse me, whatever you want me to call him) said he found the problem, it was a loose heat shield. A bolt was off, he said.
I spent a couple days crawling under the car but couldn't find it anywhere.
So I went back to Jiffy Lube, saying "Where?". They pulled it on the bay and looked again, and now they say oh sorry no the Catalytic Converter is "all broken up inside" and I will have to 'swap it out or you can put a straight piece in there'.
I checked with the auto store and looking at around $600 for a swappable converter DIY, or $250 for one which can be welded, but would require hiring a mechanic for labor.
Does this make sense? Has anyone had this happen before. I had a 2002 Jeep for almost 20 years, and another Jeep before that, and never had to change the catalytic converter before.
And if so what did you do? Seems like sudden a bank drop blowout to me, and really bad luck.... is this something common on Libertys. I know the bad luck at least is common with me and vehicles. Also how driveable is the vehicle until its fixed.
Anyone?
Anyone?
