sunroof stuck open
dimetry
denver, co
i have a sunroof stuck open. used the "auto" function to let the sunroof open all the way on its own. I think it pulled the headliner portion too far back, got jammed, and is now preventing the sunroof from closing. at least thats what i think is happening. When pressing the sunroof button, i can hear a click but no movement. I tried pulling the headliner shut but it does not budge. Has anyone had the same problem? any suggestions how to fix it? thank you
Kasmir Jones
Bergen County, NJ
best bet is to put power to the motor to close it for now. The issues im having with mine are different. My fuse keeps blowing. I think I tracked it down to the sunroof control module. I haven't messed with it in a while.
gtommec
I know that every car that I have had with a factory sunroof had a way to close the sunroof manually in the event of a failure (with an allen wrench, etc.) does the KJ not have this option?
dimetry
denver, co
i am still trying to figure out how to close the sunroof manually. The window seems to be stuck solid, i tried pulling and it doesnt even budge. I still think the headliner portion of the sunroof is whats causing the problem, it just looks like its further back than i have seen.
Kasmir Jones
Bergen County, NJ
I cut the cig lighter power cord from an old portable air compressor. I unplugged the harness to the sunroof motor.Plug in the power cord to the back outlet. Attach the cut wires to the sunroof motor. Have someone hit the switch. This will close the roof or tell you if the motor is blown.
