LONGJEEPOWNER
My summer tires are 225/75/16 and this year I acquired a set of studded 225/60/16 which I had mounted on a set of steel rims. I knew I would have a problem with the pressure sensors because there are none on the steel rims, but when I started to travel down the road my ESP, Traction Control, and brake light came on. I know why after some thought on the back tire size. I turned the Jeep off and restarted it and hit the traction control button to disable it. None of the other lights came on after a long ride!
My question is can I do any damage to the Jeep by running it in this fashion for the winter? Will I unnecessarily wear my brakes out? Will I do other damage?
any help from the community would be appreciated.
I would have bought the proper size tires as the front but Christmas has tapped me out....
Thanks in advance
Thanks in advance
