Logan Savage
Higher mileage automatic transmission that you don't know the maintenance record of . Transmission works perfectly , fluid change / flush or not ? One school of thought says yes , another says no . I personally disassembled an auto trans. & there was gunk hiding in a lot of little nooks & cranny's . I can see the logic behind the school of thought that says don't do anything to cut this gunk loose .
There's also the school of thought that says , bunk , change that fluid and or get a flush , the trans. fluid needs changed . I can also see the logic behind this school of thought . I also have read that lubricants don't wear out , they just get dirty .
There is a man locally that has a shop at his home & makes a living rebuilding auto transmissions . He evidently is good as he has a very good reputation in this area . My father-in-law had a transmission rebuilt by him & he said the man told him it was a mistake to change the fluid in a transmission that had fairly high mileage & hadn't been serviced regularly .
A family member had a ford ranger that needed a transmission . He purchased a salvage yard transmission , installed it & it worked properly . He changed the fluid & filter & the transmission immediately went south . The salvage yard had warranted the transmission so he removed it , took it back & they gave him another one . Did the exact same thing with the 2nd transmission . It worked properly , fluid change & it immediately went south , he parked the truck after that & didn't fix it again .
Now I'm in the same boat with a jeep liberty I bought that needed an engine & I'm in the process of installing a low mileage engine in it . To mess with the automatic transmission fluid or not , that is my dilemma . The transmission is / was working properly when the jeep was parked due to engine problems . As always , input is what I'm looking for & would appreciate .
