I have a 2012 Liberty with the Mopar skids (radiator, engine, transmission, xfer case, and gas tank). I recently got back from a offroad / camping trip and inspected my undercarriage to discover that for the engine skid, the back passenger side bolt was missing / the driver's side bolt appeared to be quite loose and chewed up pretty bad. I tried to tighten it but it just spun. I then took off the engine skid plate to look closer at what was going on and the threads for those two rear bolt holes are simply missing.
It's been a few years since I installed these ... but I remember that the cross member had threads that I screwed those bolts into ... I don't remember putting nutzerts there. So I'm guessing that at some point during the trip the pressure the skid plate was under somehow dislodged the threads that were there. I'm not sure.
I did look on the other side of the crossmember ... I think on the passenger side I could drill through it and bolt from the top. But on the driver's side I'm not sure that is possible due to the design. At any rate I thought I'd post to see if anyone else has experienced this and had suggestions for how I can secure the back of the plate (these bolts also hold the front of the transmission skid plate on).
Thanks,
GR
Thanks,
GR
