PaulP38a
New member here, but have found this site to be very useful as an anonymous Googler/reader for the past 18 months we have had a 2002 KJ Limited 3.7L, so thanks so far!
Last week it was running like crap and threw codes P0351 and P0352, indicating a coil problem on 1 and 2.
First thing was a new set of spark plugs. Couldn't get the NGK ZFR6F-11G so got a set of Bosch FR7LCX+ which should be a direct replacement, right?
Reset the fault codes, and started the engine. Still sounded rough and the codes appeared again after a few seconds.
I then swapped the coils around with 3 and 4 to see if the fault followed the coils, but it stayed on 1 and 2.
I bought 2 new Denso coils anyway and put them in. No difference.
Then I spent several hours with the FSM, a multimeter and pen/paper:
If you agree it is the PCM, this one is p/n P56041609AF
I see there are a few different models out there. Guessing I can't swap in a P56044xxxyy, but can I use a variant of the P56041xxxyy, P56041609yy or does it have to be the P56041609AF specifically?
Thanks for your time.
- resistance on all coils, old and new, was in range for both primary and secondary
- resistance on all spark plugs was in range
- continuity test on all wires from C1 (1,3,5,7,21) and C2 (9) to the coil plugs was good
- resistance test on all wires indicated no unwanted grounding. C1-31 and 32 are earth as I recall. Tested with both battery leads removed and all coil leads unplugged, plus C1, C2 and C3 at PCM.
