Tires and Wheels
jeeplib05
Ohio
I found a great set of 31x10.5r15 General Grabber AT2 with American Racing Outlaw 2 rims, only about 1,000 miles on them. Would these work if I installed the 3.5" Tommudd Ironman lift? If not what would I need to do? (won't buy if I need to do serious modding, although I'm not worried about doing some if needed.)
Edit: Backspacing is 3.7" if that helps
Bad backspacing plus 15 inch wheels highly doubt they would work , only aftermarket steels work in 15 inch, not cast aluminum
Won't clear the calipers
PLUS you're in the range to regear at almost 31 inches tall
Other than that, the TM Econo lift would work great if you choose the right parts
jeeplib05
Ohio
So if I get a set of 31x10.5r15 tires with 15x8 steel wheels with 4.5" BS would that be good (TM Econo 3.5" Lift installed)? Would the tires stick out from the fenders any and not rub? (Goal)
