Tline155
I was wondering what the tow rating was on the Liberty. I have seen a few different ratings when doing some searching.
Open your hood, if you have both the engine driven fan AND an electric fan then you have the towing pack.
Yes,and if you have the tow package you should have all the extra coolers to.I've towed a trailer wieghing 5000lbs from SD to WA and then from WA to CO(both trips 1500 miles through the mountains) and I don't have the tow package but added a AUX ****** cooler rated for a 28,000 GVWR vehicle and I have the 45RFE ******,had no problems(except stopping).One time for a total of about 30-35 miles towed 6200lbs with my KJ,no problems then either.So, they both use the same radiator, just an extra fan w/ the towing package?
Not true for '02 KJ's,you could get the flat-4 wiring instead of the 7-pin,I can't say for '03+ KJ's.tow package comes with a 7 pin wire harness, so yes, wired for a trailer.
