I ordered new trans cooler lines for my '06. Has anyone replaced these before? The service manager at the dealer warned me that they are "a real *****" to replace, and that a special tool is needed for the connections. Any advice is appreciated.
Haha, my bad.. Didnt see the 'lines.'
There not real hard to replace if doing on a lift but will be a pain doing on the ground.
The mechanic I talked to (who I know and trust) said that he wouldn't do that because of the pressure in the lines.
When the vehicle is off there is zero pressure in the trans cooler lines since the engine needs to be running for the trans pump to work.The mechanic I talked to (who I know and trust) said that he wouldn't do that because of the pressure in the lines.
dude
you still have not answered why you are going through all this
why are you doing this?
are you having problems with your current lines?
just replacing 3 year old parts for the sake of doing it is asking for work
if you like work that much...
my yard needs mowing
my Jeeps need a good cleaning
the trans fluid on the TJ should be changed ,wont hurt to change the KJ while you are at it
I need the north side of my house washed ,green slime on it
I need to get some crown molding up in my living room
if this is not enough to keep you busy I can think of more
Just kidding
Dude, why do you think? For fun? One of the lines is leaking at both crimps.
The easy fix is
remove dinky crimps ,if they are the ones that you take off by squeezing
