Transmission Cooler Lines
permethrin
new york
Can anyone please tell me the correct part number for the transmission cooler lines for a 2006 Liberty Sport with the 3.7l v6. I believe I found the correct part number which is 55037785AE, I just want to confirm this as the illustrations in the parts manual do not look like the lines on the jeep.
TwoBobsKJ
Northern Ohio
Was it around $95 for the tube assembly? Then yep, I believe that is the correct part. The diagram may not be exactly like yours but more than likely the part you'll receive will fit fine. :waytogo:
permethrin
new york
Thanks for the help, that was the correct part number, now all I have to do is figure how to get these snaked in under the jeep. Does the radiator need to be lifted to get the front part of the lines under or can this be down without that?
TwoBobsKJ
Northern Ohio
No, you shouldn't need to remove/lift the radiator. The flexible rubber hoses go to the side of the radiator and in front to the external trans cooler. Snaking them under the front diff and around the ****** will be challenging but take your time and have a helper nearby :waytogo:
ivantate
Illinois
I lifted the rad as I didnt want to be twisting the new pipes too much and I couldnt see that the was enough room.
Maybe did too much but got it done.
Sent from my SAMSUNG-SM-T217A using Tapatalk
