For months now iv had an odd sound get progressively worse. It started as almost a whistle that you'd only hear while driving under bridges or near barrier walls, but has now progressed to a full blown metallic jingle/occasional clunk/ratcheting sound that seems to be relative to wheel speed. It clunks and ratchets at lower speeds 0-10mph occasionally. It ALWAYS makes the jingling sound almost like a small chain bouncing off the road beneath the jeep that gains pitch as you gain speed.
Iv gotten under the jeep this morning and turned the driveshafts by hand and they do have back and forth play. The front driveshaft is very audible when you try to spin it making a fairly loud click with a light clunk. Is this normal for jeeps? I'm starting to think I might have a bad U joint. Any ideas or suggestions as to what to check? Iv recently put all new brakes and rotors on. Checked differential fluids, CVs are in OK condition, no drippy wheel bearings and no transmission leaks.
