Hey guys,
So I'm getting some shudder and I can feel a bit of movement at the U joint on my Liberty 04 3.7L.
Looking at the parts on Rockauto, they seem specific to mostly the rear driveshaft, or front at RWD:
If I want to replace them, I need one for the read driveshaft at transmission I believe?
For the front, which one do I use if they're saying Front RWD?
Thank you so much!
Edit: I think I just realised the front is the transmission one? So it's the same as the rear axle one?
So in that case, can I just use 2 of these? https://www.napacanada.com/en/p/NPJ...+Joint)&impressionRank=3&keywordInput=u+joint
Thank you so much!
