Honestly, I got tired of having to hunt for quality Liberty parts in that department. I just went online and found a fj cruiser roof rack, fits the same dimensions and actually has lots of people still making accessories for them.Want to get a roof cage installed but have no usable rails to attach cross bars to. Help.
Can Comfirm.OK. lots of TLDR here so...anyway..
There is absolutely nothing wrong with the OE rack other than it lacks cross rails. The weight limit has to do with the strength of the actual roof and the ROLLOVER rating. The Liberty has a high center of gravity, that gets worse with a lift...hence 150lbs max. Sure you can do more weight, but it makes your vehicle dangerous to drive. As someone that actually does "jeep stuff" fully loaded with camping and scientific equipment on a regular basis, here is what I suggest.
Step 1.
Here's what you need for reliable and properly fit cross rails. I have used them for nearly a year and had all sorts of stuff loaded up on them in the basket. They fit like they were designed for the liberty because they were. In Germany. Don't let the price fool you.
Step 2.
Add your Choice of roof rack. I use this guy currently but will be upgrading to something a bit wider in the near future.
Step 3.
Relax. Problem solved.
