Many many applications
First let me tell you that this is one of my top 10 products I have ever used . right up there with PB Blaster. Back when I was in the Marine corps I was introduced to it . It worked so well that I started to try using it on other surfaces . The first was the commertial Marine Corps White Dodge Van. The areas right around the door handles and there you grab to close the hood etc . Would not come clean . I tried to spray all types of cleaners and the base truck wash but it never came clean . Then I tried this stuff and as soon as I sprayed it the grime started running off. Do not let it dry on the paint . Spray it on and rub it in a little and hose it off. Like fresh paint. Just wax when you are done . . The latest use was on our Commertial carpet , Low pile , Synthitic fibers. The carpet had Black roofing tar on it . All of the carpet cleaners whe have used in the past ( Big ones) failed to put a dent in it . so I diluted it 50/50 with H2O and sprayed it on , worked it in with a brush and then placed a towel over it and walked on it to soak it up .
Wham , I removed the towel and the carpet not only had the roofing tar gone but the carpet was bright clean .
Worked so good I went and got a carpet cleaning machine and went to town , Looks like new carpet . . I have even used it to clean the ( Please pay close attention ) lap top I am using now NOT THE SCREEN < DO NOT USE ON THE SCREEN I just spray a little on a wash cloth to SLIGHTLY DAMPEN , then wipe down the case and the keyboard , even the track pad . Looks like a new computer .
OK Its drawn out now , what not to use it on ( Cotton , Wool ) Leaves a slight blue tint to it . Do not spray on Poly carbonit headlights , Turns them white , Spray in a well ventolated area , Smells strong.
And it is speeled Bleche instead on Bleach . There is no Sodium Hypocloride in it . Sodium Hypocloride is bleach at 4.75%
Sorry to bore you .
I gust bought 6 Gal of the stuff today.
