What should I do
KJJosh
Northern VA
I have 245/70/17 Destination AT tires installed and I have a rubbing issue. It appears to be rubbing on the bottom airdam on the front bumber while turning.
Should I cut the damper or replace the bumper? I need to see pictures of everyones front bumper to see how you cut it......
I'm also rubbing on the inner fender well when going off-road and turning at the same time... anybody got pictures????
KJedmonton
Edmonton, AB, Canada
How tall is your lift, because I was under the impression that a 30.5" tire would fit a lifted KJ??? :confused:
ThunderbirdJunkie
Bronze Supporter
Newport, KY
It's just plastic. Get a heat gun from a hobby shop (~$15) and use it on the offending plastic to heat it, then push the plastic inward to make it stop rubbing.
Plastic rubbing doesn't hurt nothin
Or just give the tires a few thousand miles to wear a bit, if it's a minor rub.
KJJosh
Northern VA
Not a bad idea TBJ!!! I think I'll pick one up on my way home from work tomorrow
ThunderbirdJunkie
Bronze Supporter
Newport, KY
It's the only way to fly. Plus, you'll find many other uses for the heat gun after you buy it.
One of ThunderbirdJunkie's favorite tools.
J-Thompson
just south of doucheville
all I used to fit 245/75 MTR's on OE wheels on our '03
was a heat gun ,and OME med springs all around
need to drop the rear bump stops about an inch or less to stop the rear rubbing at very full stuff but like was said rubber on plastic = rubber wins
