Hi Jeepers,
I have been monitoring the sound of a bad wheel bearing in the front for a little while, and couldn’t quite tell which side the grrrrrrr sound was coming from. Came home last night, 15 mile trip, parked it. Well today I went to drive it and there was a terrible squeaking/squealing from the drivers side before I went a few blocks. Something was seized in there, and it eventually broke loose when I put the Jeep in reverse, so the wheel does turn freely again. However, I am not thinking this is safe to drive anywhere.
I have a hub bearing replacement, Mopar, waiting to go in. Today I took the wheel off and attempted to do that job. But no dice. I only got as far as the axle nut. It’s crazy stuck. I used:
- lots of PB Blaster
- A hammer on the 35 mm socket
- An 18 inch breaker bar, standing on it
I would have tried this with the wheel on, and my pipe extension on my breaker bar, except my 35 mm socket doesn’t fit through the hole in the wheel. Instead, my pipe extension is holding the wheel steady while I try to turn the nut (see photo). I couldn’t get it to move this way. I need more leverage.
My 35 mm socket is impact quality, so maybe it’s thicker than the average socket that could fit through the wheel. Should I look for a thinner one?
What else would you try? If I can’t get the nut off, it’s over, and I’ll have to call for a tow to a shop.
Please advise.
Please advise.
