Hello everybody. I am new to this forum. I've read great stuff all over the site but finally had the need to actually post something.
So I had a bad wheel bearing, I was getting these growling noise every time I braked. And there was also some noise when the car was going forward. I did the job this past weekend. While I was working on those bearings I decided to change the rotors too. I did not change the pads because i did those less than 6 months ago.
After I changed the bearings (rear end), the growling noise was gone but then I started to hear this "tapping" noise, (very similar to a bad bearing noise). Please see the video attached to this post. The noise gets louder the faster I go, but can be noticed even when going at low speeds. The noise feels like it synchronizes with a vibration, mostly from the right side (When driving you can see the passenger seat shaking/vibrating). When I make a right turn, the noise/vibration becomes less severe and if I go straight or turn left you can definitely hear it/feel it.
My first theory is that the axle was worn out from the previous bad bearing I had installed, and now with the new bearing on there is excessive play in the axle making it even worse than before.
Second theory, is that I damaged the new bearing when I installed it.
Third theory, is that I have a bad front right wheel bearing (which I don't think, but you never know)
Fourth theory, something like suspension???
I am not a car expert but can do some things, please take a look at this and help! Thanks in advance!!
[YT]hmpyT0yPriQ[/YT]
