Lesman
Where is the engine block ground located? Any pictures?
IDK if you have the 05 factory service manual, has it all including grounds & even noise suppression info ++++
http://www.colorado4wheel.com/manuals/Jeep/KJ/2005JeepKJServiceManual.pdf
Ahh! I found it! 06 parts diagram of all places. M8 x 1.25 stud!Any idea what size these bolts are that go into the heads for the ground straps?
on my 06 KJ, when the ‘shop’ did the 3 month engine swap for the last owner, they conveniently snipped the ground straps off.
All the kj’s at my parts yard have donated their engines, and likewise, the ground strap.
Hello Guys, i hope this pictures and information can help someone else.Beside two ground straps posted by LibertyTC, there is a main one connected directly from battery to engine block.
It is not easy to get to it, right behind oil filter, must removed engine mount bolt to the frame to get to it.
