Which rear axel do I have?
Corytrade
Northern California
So I am doing all the fluid changes in my Liberty (05, V6, came with tow package), and I am not sure which rear axel I have. The identifier is missing on the differential. The Haynes manual says the model 35 requires 75W-140, and the 8.25 rear axel requires 75W-90. I do not do any towing, even though it has the package. I just jacked it up and did a LSD test, and it is not limited slip. I looked to see if there is an identifier from the VIN, but couldn't find any info.
Marlon_JB2
Kombat Edition Jeep
Harrison Township, MI
I don't remember exactly the rhyme or reason, it's been so long, but I do know that every 3.7L and 2.8L CRD got the Chrysler 8.25 for that particular model year.
With Your Vin Number walk into any Chrysler Dealer & obtain a free print out of the Jeep's options/build list.
It will not only tell you which differential you have open or trac-lok, but u can see all the good stuff from fogs to alternator to well..everything!
The standard is 8.25 corporate axle and I use Lucas gear oil. 75w-90 is standard if not trailer / pulling.
Here is what a trac-loc looks like inside, and it does require the Limited slip Chrysler additive as well.
Adding a limited slip additive will not hurt an open carrier if u really are not sure.
48620[/ATTACH]"]
8.25, very few of the early model 02s had the 35
none after that
Use regular dino gear lube, no need to spend a lot of $$$ on the fancy named diff fluids. Dino gear lubes stick to the gears much better than synthetics etc
You can run any of the weights mentioned without issues
