will this work
Well it all depends, sure it will fit, works better on a 7 inch wheel
plus depends on what you are going to install it on, how much lift you have and what gears you have , then also the backspacing of the 8 inch wide wheel
Asking that question just opens up a whole bag of other questions
If its going in the front yard to plant flowers around it by all means do it
I'll add that you know that its a 32 inch tire, if you are installing it on a KK then 4 inches of lift, regear and again depending on the backspacing it still may or may not work
tea eye
buffalo
im new to the whole jeep thing so im unsure. would a 31/10.5r15 on a 15x8 wheel work better ... i dont have a lift yet either btw
If you don't have a lift yet, give up on a 8 inch wide wheel plus anything over a 30 inch tire. They are going to rub.
And also there isn't a tire that we can run that really needs a 8 inch wide wheel , 7 inch work better and unlifted you have to stay with the same backspacing as stock
