Cool Javelin
The window has come detached from the regulator, and as such, gets jammed in the window frame when running the window up. I am able to pull up on the front of the glass and Micky Mouse my way to closing the window.
I want to replace the assembly, but I find there are more then one choice and I'd rather step up the clearly poor design I have.
RockAuto keeps mentioning "Hole Style." I think this is what I have, but this seems to be a design flaw. The glue at the hole has broken allowing the window to pivot. Is there another style? They also list parts both before and after Feb 25. Are they interchangeable?
I have found more robust looking mechanisms like this one https://www.quadratec.com/p/crown-a...-power-window-regulator-liberty-kj-68059645AA. I assume I must also replace the glass?
Also, and maybe less important, I see mechanisms that push and pull on the cable from one end, vs ones that pull only from both ends.
Can I get recommendations. If I get the later style regulator, must I also get the later glass?
Does anyone have experience repairing the existing flawed design?
Can I do the junk yard thing from a '07 Liberty? Will it be the new design, and will it be more reliable?
Thanks anyone for your help,
Mark.
Mark.
