Liberty 3 hole rear brake backing plate/ dust cover.
jrsavoie
Clifton, Illinois
Does anyone have at least one rear brake backing plate/ dust that held on by 3 holes?
I have a 2006 Liberty CRD. I think the rear differential was changed out. Possibly with a newer year.
I was going to order the 4 holer 2 piece and see if I could make it work, but there's not enough left of my backing plates to figure out how to do that.
Thanks
2006 Jeep Liberty CRD Emergency brake dust shield/backing plate
The left one was all but gone, the right was still there, I had the Jeep at a trusted shop yesterday, because the 1994 had the shop space plugged up.
Neither I, nor the shop, can find replacement backing plates for the 2006 with 3 holes.
Our 2006 Jeep Liberty CRD has 3 studs that hold the backing plates on.
The 2003, 2004 & 2005 have 4 studs.
I saw in a review that this backing plate didn't have the wheel speed sensor hole that started in 2006.
I am confused as others have said they gad 4 studs to hold the backing plate on, on a 2006.
I did rears about 7 years ago. You'd think they would have lasted longer. Might have got driven with the Emergency brake on.
Now the pads are off both sides. I need to disable the handle or something, so nobody tanks it.
u2slow
BC
I see them on rockauto - parking brake adapter. Out of stock. But the mopar # is there to search with.
jrsavoie
Clifton, Illinois
I haven't found anything.
And I never got notification of your reply.
I checked my settings and thought I had it right.
I think everything as far as brakes is the same 2003 to 2007, except the wheel speed sensor 2006 & 2007.
There's not enough left of my backing plates to tell.
I was hoping someone was doing a part out or rear axle conversion and would have parts for sale.
I've seen complete rear differentials for sale, cheaper than the parts I need.
But I be can't find them now that I'm looking.
Not sure to mention I'm having health issues and have limited productivity.
jrsavoie
Clifton, Illinois
Check www.car-part.com too. Whole rear axle assembly should get sufficient hits.
I checked around when I was just looking for the backing plates. Never got any hits.
It just crossed my slow mind today to look for a whole axle assembly.
If you hear of anyone That's looking for an axle assembly because theirs is trashed, I might be able to help them out a little by buying what they have.
