2012 Front Turn Signal
RikVesp
2012 Liberty Jet....Front left (D/S) turn signal works during the day, but not when headlights are on. Also, the marker light doesn't work at all. I already redid the two ground clusters under the brake fluid reservoir, but that didn't help. Any ideas out there? Desperate to fix this as car need to get inspected.
Rich
turblediesel
memberable
Alaska
I ran extra grounds to my '05s front turn signals as a workaround for my intermittant blinker problem.
Aeroscott
California, USA
It's probably your multi-function switch, I have had my 08 KK go thru both wiper/washer switch and headlight/turn signal switches, check fuses, grounds and bulbs and sockets, if they are all good, it's probably the switch. don't buy a cheap one, I got a deal on a Dorman wiper switch and it only lasted 1 year before it started flipping the wipers on all the time.
