Clevis bush replacement
DeVilliers
Morning all,
The clevis bush on the Jeep need replacing. The right side being more shot than the left. You can actually here a "clack, clack sound.
I two new bushings from Moog. The Jeep has a 2" lift and I remember, when installing the lift kit, it was a pain to get the strut in and out of the clevis bush. Compressing the spring, using a jack and a few strong words.
So, two questions:
1. Is there an easy way to do this?
2. How do you get the old bushing out and the new one in without removing the control arm?
Thanks
DeVilliers
Morning all,
I have two new bushings from Moog. The Jeep has a 2" lift and I remember, when installing the lift kit, it was a pain to get the strut in and out of the clevis bush. Compressing the spring, using a jack and a few strong words.
So, two questions:
Thanks
Bump
duderz7
Weiser, ID
Use a ball joint press to push the deteriorared rubber out of the sleeve, or drill a bunch of holes in it and cut it out. Then collapse the sleeve by using a punch to relieve pressure. Then use the ball joint press to put the other in. As far as clevis fork. Detach sway bar from control arm and it should be a lot easier.
Mine are shot too, just ordered some Moog replacements.
NewIn4x4
Need to replace mine too. Is there any way to press these bushings out, without drilling or cutting? Thank you.
Possibly if you make up a puller but they are usually tight and rusty
duderz7
Weiser, ID
Plus they have a flange on them that is bigger than the diameter of where they're pressed into whichis also rounded. No puller fits or holds.
ikuo78
Japan
I had the lower ball joint and lower arm bushes all replaced at the same time at a shop.
It cost about $300 as wages, so I think it would have been a good idea to buy the special tool 8858.
In the US, you may be able to get the lower arm ASSY at a low price.
My experience doing this was I had to remove the arm, drill multiple holes in the rubber bushing, put it in my press and push out the center, then take a sawzall and slice the outer metal sleeve, then tap it out with a hammer & screwdriver. Then I pressed in a new Moog bushing. I hope you can do it easier!
Pics of the main LCA bushing but same process:
Pushed out the center using a large socket.
The center. You can see the drill holes to weaken the rubber.
What's left in the arm
Carefully saw through the metal sleeve.
Tap out metal sleeve with hammer & screwdriver. The metal should collapse inward and come out easily.
Hopefully the sawzall didn't damage the arm. A small mark is no big deal.
Next, press in the new bushing. I had sockets and various pieces from a ball joint press kit that I used to stabilize the arm and get a good angle on the bushing while pressing it in.
