Btownpreacher
- Joined
- Nov 13, 2022
- Messages
- 124
- Reaction score
- 102
I’m having trouble on my 05 CRD. I have an under boost code as well as a maf low circuit performance. The turbo seems to be struggling, but I think I might also have a boost leak. The CAC hoses have already been replaced with silicone and I’ve checked them multiple times. How do I check the intercooler for leaks, and how do I know if it’s one of the vacuum/boost solenoids? What diagnostics do I do to find out? It will build boost but the lag is terrible and it isn’t making as much boost as what it should. Recently did a full timing belt kit, serpentine belt kit, glow plugs, and the Sasquatch parts fuel pump kit. That’s when it started getting worse. I redid the timing to make sure it was correct and the only thing off was my injection pump. I did all the work because it had a horrendous metallic rattle. After the work it was still there. Did a cylinder contribution test and the cylinders are all firing fine so it shouldn’t be a valve train issue. Not sure where else to look. I know it’s under-boosted so I’m starting with that.
