Does anyone have info on compatible suspension swaps?
LondonLew
04 Liberty, 3.7
I cant imaging that there isn't any other option for suspension in the liberties. If you're unfamiliar with this method., the best example I can point you towards is putting Ford Escape suspension components into a Ford Focus. Same bolt pattern/mounting. Just take the longer stiffer springs and squeeze them into a smaller space to make a lift.
u2slow
BC
I looked at dakota and grand cherokee. Not similar enough.
I don't know of any swaps but if you look on here there is a lot of information on upgrading the suspension.
duderz7
Weiser, ID
I've heard of people using jk springs in the rear but I have no further information.
did OME stop making springs?
u2slow
BC
Im using 4runner coils back there for some lift. (97-01?). Cut the first small loop off the end. They are on the soft side though.
Edit: 99-04 grand cherokee has a similar rear boomerang upper arm. Might be useful for an axle swap.
