Fixed Dipstick Tube
RobertPH
Riverland SA
Just to show what I did - with much cursing and more swearing I dropped the back of the ****** and managed to get the back broken piece of the tube out. No (jeep) wreckers I contacted had a part and finally did find an OAM one in the states. $121 to get here but wouldn't be here for 6-7 weeks so they say.
No matter this is what I did - The tube is 19mm so I got a 6 cm piece of rubber tubing with an inner diameter of 20mm, the one that doesn't deteriorate from oil and put both ends into the rubber tubing - clamp on both ends and waalaa.
I was told that vibration cracked the original one right at the top of where the retaining bracket was.
The tube itself is very very thin so they couldn't weld it- some sort of brazing might have done it but i bit the bullet and well a picture tells a thousand words.
and it's the exact same length as an original.
