Found Rust hiding under.....
ptsb5a
Northern Alberta, Canada
Changed out the bulb for my third brake light today and found some corrosion hiding underneath. Thought you might like to know.
Here's where I found the paint rubbed away and rust starting to show. Note that it was at the same place on both sides.
And here's the culprit. Poor design of the third brake light housing. There are tabs protruding on the back side on both sides. I trimmed them back with a utility knife before reinstalling the lamp assembly.
I scrubbed the affected area with a 3M prep pad and applied a rust neutralizer. Then applied primer with a cotton swab and when it was dry I used a little black enamel, also applied with a cotton swab.
I'm sure that if not caught in time, the cancer would be way harder to get rid of. It would spread out from under the lamp and really be a PITA.
Cheers all
Ian
Atrus
Metro Detroit, MI
Thanks for the head's up - I'll pull my light off this spring and make sure to do preventative work on it! I know this is a common KJ rust area.
No rust, but the paint is scratched wear you mentioned, ptsb....and the on mine needs to be polished...
I will check mine when I do my spring maintenance routine. Thanks for the heads-up ptsb.
Luke
Interloper
Bancroft, Canada
Grrrrrrr ...and ^%&^*&!
Thanks for the heads up dude ... looks like I have some work to do!
ptsb5a
That is EXACTLY what mine looked like, except in black of course. What a sh!tty place to let that start to happen. Stoopid engineers.
m_volyrakis
Greece
It's 23:00 hours here and you got me thinking doing down to have a look...:(
family KJ
JPOTM WINNER
Tampa, Florida
Ditto that, I noticed mine last week although mine is a bit more outside if the 3rd light area which is worse....I can't match the paint to fix it.:mad:
Luke
Interloper
Bancroft, Canada
I just finished 'dremmeling' mine smooth. It looks like just a half-assed trimming of the plastic housing after it came out of the mold. Vibration rubs it against the paint and rust soon follows.:mad:
Prospect62
New Hartford, NY
If that's all you guys got, you're lucky! I have rust bubbles (and rust coming through) along my passenger side roof drip rail, around my glass liftgate hinges and on the driver's rocker panel in front of the rear tire.
Thanks NY road salt!
