- Joined
- Dec 17, 2006
- Messages
- 10,612
- Reaction score
- 40
heck they might have to grind some installing 4.56's in the 8.25.The 8.25 has no carrier break and why mods are required for gear sets lower then 4.10's as the 8.25 was never designed for lower gears then 4.10's.Thanks Tom that starts to make sense now. So do you think this is not too much trouble to fit the 4.88? I won't be doing the job myself but I was worried to start telling the guy who will do it that the gear and pinion would not fit in the differential without grinding the teeth.
There are some real oddball setups out there now.I have a high pinion D60 center section in the rear of my KJ(RockJock60) and at the time to get 5.13 gears that were not reverse cut(for front apps only) I had to get a ARB locker for 4.56 gears and higher and use Motive Gears "thick" 5.13 gear set.
