Help! Tire size and wheel offset
Back-
spacing​
3.25 in.​
3.5 in.​
3.75 in.​
4.0 in.
4.25 in.​
4.5 in.​
5.0 in.
5.25 in.​
5.5 in.​
5.75 in.​
6.0 in.​
Wheel Width​
Offset (mm)​
5.5 in.​
0​
6​
12​
19​
25​
32​
44​
52​
57​
63​
69​
6.0 in.​
-6.4​
0​
6​
12​
19​
25​
38​
44​
51​
57​
63​
6.5 in.​
-12​
-6​
0​
6​
12​
19​
32​
38​
44​
51​
57​
7.0 in.
-19​
-12​
-6​
6​
12​
25​
32​
38​
44​
51​
8.0 in.
-32​
-25​
-19​
-12​
-6​
0​
19​
25​
32​
38​
8.5 in.​
-38​
-32​
-25​
-19​
-12​
-6​
6​
12​
19​
25​
32​
9.0 in.​
-44​
-38​
-32​
-25​
-19​
-12​
0​
6​
12​
19​
25​
9.5 in.​
-51​
-44​
-38​
-32​
-25​
-19​
-6​
0​
6​
12​
19​
10.0 in.​
-57​
-51​
-44​
-38​
-32​
-25​
-12​
-6​
0​
6​
12​
10.5 in.​
-63​
-57​
-51​
-44​
-38​
-32​
-19​
-12​
-6​
0​
6​
11.0 in.​
-69​
-63​
-57​
-51​
-44​
-38​
-25​
-19​
-12​
-6​
0​
12.0 in.​
-69​
-63​
-57​
-51​
-38​
-32​
-25​
-19​
-6​
Rstep21
Hi Tom
I just installed a lift on my 06 KJ with the 3.7. I used OME 927 with Bilstein 24-282642 on the front with a rough country 2.5 on the rear. The measurement for the front from center to flare is 22.5 and the rear is 20.5. I haven’t driven the Jeep but maybe a mile because it has no tag for now. What can I do to get the rear up to match the front besides changing the springs and shocks again? Also, what size tire can I run with a 17” wheel and can I run a wrangler wheel with an adapter and do you know anyone with a set of UCA’s for sale. Thanks
Dirtyrat
Hello guys I have a 2009 Jeep Liberty North Edition and I just lifted it with 2.5 Suspension lift from Rough Country and I'm planning to buy a new set of wheels and all terrain tires. Does anyone runs with 16x8 with zero offset? And what size of tires that will fit this setup? Please help!
I have the OME 3.5” lift and subframe drop. Run 265/65R17 tires and a zero offset. Did do a very small bit of trimming and removed the inner fenders.
Rstep21
Are you running the UCA’s and what did you do to do the subframe drop?
Dirtyrat
I just got some one inch spacers. Jack the vehicle up
Dropped my front sway bar for access to bolts
Then loosened 4 bolts to an inch or so
And removed one bolt at a time inverting the spacer, purchased at Home Depot, then after all spacers are in tighten up and reinstall the sway bar. Easy job. But I am looking for better spacers. I think they should be wider than I have.
