How to connect backup camera to reverse light on drivers side
OxleyT6899
Hi! I have a 2008 Jeep Liberty. I just installed a third party double din touch screen stereo that came with a backup camera to install. I’ve run the wires from behind the radio to my back tail lights. I know I need to connect the red and black wires from the back up camera to the reverse light but I’m not sure which wire to connect it to. Seems like everywhere I look online has different wire colors. I’ve attached what my wires look like below. Thank you in advanced.
Just hangin' out.
Stick a paper clip into one slot of the female connector on the driver side. Have a helper step on the brakes. Measure DC voltage between paper clip and a chassis ground. Wash, rinse, repeat till you know which is the hot. Most likely is one of the white with green stripe.
