Looking for suggestions!
woodman51
LOZ
2002 Liberty Sport 3.7 4WD
I had no issues or symptoms until I came out of a store and had a hard time starting, running rough, and stalling when slowing for turns/stops. I have replaced: fuel pump, fuel filter, all plugs, all coils, and all 02 sensors, checked and replaced questionable vacuum lines/fittings I could identify. I get no codes other than for air bags and impact sensors.
Hoping for someone with more experience to give me some insight .
I have learned a lot from this forum, and it is definitely appreciated!
duderz7
Weiser, ID
Clean iac and throttle body, also check air filter and clean air flow sensor. May not fix your problem, but is really inexpensive and certainly wouldn't hurt any.
woodman51
LOZ
Thanks for the response. I forgot to mention that I have also replaced the IAC and TPS, as well as the air filter, and cleaned the throttle body....this thing is giving me fits!
SPYROS060120
Hello woodman! Same problem here with a 2.4KJ. Somewhere in this forum I read it’s the MAP sensor. I’m replacing it tomorrow and will let you know.
turblediesel
memberable
Alaska
A bad vaccuum leak would cause all those symptoms before engines had brains.
Xterra4x4
Did check MAP sensor? Or vacuum lines (connects to intake manifold) also does cruise control work if not there's a vacuum leak!
