problem solved idler tensioner crd
lacasadel4x4
problem solved
idler tensioner crd
5072447AB​
5072447AB 05072447AB K5072447AB K05072447AB 5072447AA 05072447AA K5072447AA K05072447AA 5072447AC 05072447AC K5072447AC K05072447AC 5072447AB 5072447AA 10214/01 20512913F 2913F 05072447.AB 05072447 K5072447AB K5072447AA 20512914 VM20512914 K05072447AB K05072447AA. 5142661AB 05142661AB 10227/02 3052F K05142661AB K5142661AB. 5142661AA 05142661AA 20513108 20513108F 3052F K05142661AA K5142661AA 5142661AB 05142661AB WR01565
That's not the idler tensioner! It's a replacement bearing for the fan hub!
turblediesel
memberable
Alaska
That's a pretty special bearing! Three bearings on the shaft; two of them preloaded against each other. Nice find!
WWDiesel
Central Georgia
The fan hubs can be rebuilt using standard oversize bearings available here in the US. Does require some small amount of machine work to fit the oversize bearings.
Wonder if they are available here, I was looking at VW hub bearings as a candidate but the noise on mine turned out to be an idler so I split it and put a new bearing in. looking online using the idler number and not the Jeep number they are cheap enough not to bother again, I'll get one to chuck on the shelf.
