rear window washer
|V3nom|
Baton Rouge, LA
ditto id like to know too. mines just sprays funny, its not a fanned out spray so maybe mine just needs to be cleaned out or replaced. can you just replace the nozzle tip or do you have to replace the whole line? thatd be a pain.
I have used a sewing needle to get it cleaned out and that helped a bit as was plugged.
I have almost thought about taking a fine drill and opening it up a bit.
It is more of a drip some times not a steady wide stream.
Another wonderful piece of engineering.
