replaced front suspension now right front wheel feels like it is wobbling
gummie45
I replaced front suspension, hubs, inner outer tie rods, sway bar ends, ball joints, shocks. torqued to specs. Now it feels like right front wheel is wobbling and ready to fall off. Just test drove it about 20 ft. Took wheel off and rechecked everything. the only thing I saw was inner tie rod boot came loose at front and was sucked toward larger end. Checked the left side and same thing. Any help would be appreciated.
Sounds like you may have got something stuck behind the brake disk and the hub or the wheel and the hub.
Checked and everything looks ok. Could one wheel being so far out of alignment cause this?
How does the bearing feel with front jacked up? Any play or noise? Rock the wheel by hand and spin it, the amount vibration you are getting should mean you can see where its running out of round. It may be a faulty hub.
