SFA KJ on E-Bay
first&lastKJ
Indiana
Just saw an 04 kj with a SFA on e-bay,(dont know how to post a link). Does anyone know anything about it?
Run far away.It sat at a shady used car lot here in Colorado Springs for months and has been moving west over the last year.It's a RK 7up rework and a poorly done one at that.Looked like a 3 year old stick welded it,scary just to look at up close.They had it for something like $14,000 when in CO.
One look at the front setup and anyone with any common sense would run away from it, so much done the wrong way you could never make it right
Actually if you look up " Wrong way to do a SFA KJ " this will be one of the ones that shows how not to
first&lastKJ
Indiana
I'm not interested in buying it, I just had not seen this one on any of the forums. If it was built correctly would $10,000 be a good price?
Thanks for the link ryanee182.
What "IS" wrong with it ? Just look at the welds, look for example how everything is mounted on the front axle, in the rear they didn't even remove the old LCA mounts in front
The list could be 1000 words at least
It is a cluster **** of just cheap / bad welds/parts/planning/building everything
You would basically remove everything that was done and start completely over to try and even make it safe enough to drive
I like what the guy posted
This truly has been built for off road use, it drives ok on the road also but it really is an off road machine
Super low miles is nice, the vechile is like new inside and outside
*There is nothing you need to do with this except Drive it !!!!
:happy175::happy175::happy175::happy175::happy175::happy175::happy175::happy175::happy175::happy175:
so Techman now is the time to buy this "VECHILE" :whip:
first&lastKJ
Indiana
In the picture of the rear spring, it looks like it is almost off the upper bump stop. Or is it an optical illusion?
