Shifter bushing elimination fix possibly?
bajasoobnut
Salem, OR, USA
Hey guys, I am now starting to look initially into either modifying or even fabricating a new setup for the transfer case end of the selector system. I replaced the shifter/cable assembly on my 03 to the newer shift assembly from what I believe was a 05 that was in the pick-n-pull near my place. I put in a new bushing as well and it failed and yeeted out a little bit after installation and after finding out that it was a poor design with failures galore I decided to look into it more. I haven't done any measurements yet but I am thinking of removing the stud on the lever arm and either making a revnut or possibly new arm with a tapped hole and using a custom made brass bushing and shoulder bolt system. Possibly looking at how to redo the cable end to take a heim joint possibly.
So, just want to know what you guys think about this idea.
If it failed you have other issues as well possibly, not a bad design, parts just wear out
bajasoobnut
Salem, OR, USA
As I stated I replaced the shifter cable system with one from a 05 and this is in a 03, the bushing is the same one that is used in 07 and up wranglers and I have ran across many issues on other forums with bushing failure. The reason why I had to replace the cable and all was because I had a sleeve failure where it separated from the shifter side trunnion, was a bitch to get it shifted back into 2wd when that happened btw. So I am looking at a better system where you don't have to use zip ties or other means of keeping things together. Also I haven't shifted it into 4wd since I did that replacement so it all came apart while just driving around.
Well that one sentence changes everything then
But if you got it from a junk yard then possibly it was bad and just looked OK, before you installed it
Out of my 3 ( with a combined mileage of over 550,000 miles on them) and over 150 KJs or so that I have worked on , never had an issue with the cable or any breakage
And all have been used a lot , so just wondering you know
good luck on your quest though ;)
65Corvair
Iowa
My bushing at the transfer case age hardened and broke apart when I removed the lever to put the 2wd low kit in.
I replaced it with a nylon bushing, a washer, and a spring pin.
It has been installed over a year with no issues. It even went through Moab with lots of transfer case shifting too. :)
I had to sand to outer diameter of the bushing to get it to fit in the opening in the cable.
mercdudecbr600
They do make aftermarket (HDPE?) bushings that are replacement for the OEM (PVC?) units. Hard to get into the cable end, but feel very solid once installed. And yes, the OEM ones do tend to crack or fall apart - just like almost everything else on the KJ.
