Strut Spacers. Are these stock?
mcnaughb
I have an 06 CRD that I have owned since almost new...it had 2500 miles on it when I bought it. I am adding an OME lift to it and while installing, I found these little aluminum spacers on the front strut studs. I don't see them on any parts diagrams. Are these stock?
Link to jpg: IMG_0077.jpeg
Thanks
Can't see the photos, post them directly on here.
Jeremy-WI
Home
No pictures on rockauto for that assembly show those aluminum spacers for a CRD and I know the 3.7's don't have them in 2006
They look like a homemade boiler plate lift.
mcnaughb
Any issues leaving these on after I install the OME springs and shocks?
mcnaughb
Well its definitely got an old spacer lift on it. I guess I never really looked at it that closely. Height before I starting digging into it was 19.5 front and back.
derekj
Powell River, BC
I would probably not use them as they are putting the load of the suspension on a small area as opposed to spreading the load out over a greater area of the sheet metal. If you want a little bit more lift or just to level out the slight lean to one side a couple conduit washers under the shock would be better.
duderz7
Weiser, ID
I agree with derekj, if you want to have a spacer there it should be one peice to support the entire mount. Looks to me like the mount may also be bending, hard to tell from picture.
u2slow
BC
A slightly better version is two small scraps of flat bar with two holes drilled in each. Probably twice the surface/support area.
Another spacer alternative is the KK strut fork that you could snag at a wrecking yard. IIRC, they are 3/8" longer.
mcnaughb
thanks. i will leave them out for now and see where it ends up with just springs and conduit nuts.
