Strut Top Plates
birddog2!
Hi all,
2010 KK Getting ready to install
OME 2927 Springs
OME 2731 Springs
Bilstein 24-185660
Bilstein 24139168
Looking to bring the front assemblies to a shop to have them load them so everything is ready to install at one time.
Found this GABRIEL 143266 set on Rock auto (Pic attached) - Is there anything else the shop will need to put it together?
On a side note - If anyone is in the Tucson AZ area - recommendations on a decent shop to use - We just moved out here from the East Coast and still trying to get our footing.
THanks for any input
GreatWhiteBob
2003 Liberty (KJ)
Alberta, Canada
I’m in the same boat. Just ordered a set of KYB shock mounts for my 2003 KJ. I think that the assembly requires two spring insulators per side, so may have to order an extra set of insulators.
birddog2!
Thanks, After a bit more digging yes, two are needed
Spring Isolator - Mopar (52088686AA) for 02-12
So Top Plate, Two Isolators - would they need anything else?
birddog2!
OK Thanks, Ill have to see how long their backorder time is.
Appreciate the info.
birddog2!
Sorry, I meant use them above the stock top plate to add 1/2” of lift.
birddog2!
All good
Its the Best part about active members on forums because you will always learn about a new resource, part, tool, or trick of the trade. All info always appreciated.
