Transfer case swap
Tamir
Jeep liberty 2004 currently with 242
I want to swap in the 231
Do i have to change the lever? And is there anything else I have to change in order for it to work?
yes the lever as well or how would you know which position you are in
Why are you swapping them ?
Tamir
My current one is broken
My low gear doesnt send power to the front wheels only to the back
While part/full-time does
And i would know which position im in by feel and the dash light
Does the lever has positions by its self? Is it not all in the transfer
Tamir
i cant find any reasonable priced lever
New one in my country cost 500 dollars
So i am asking is it a must will it work?
I mean the positions are the same but there is no full time am I correct?
I would’ve just put a 242 but i cant find any and i have heard that the 231 are stronger
Are you sure the box is broken? Check the linkage and bushes.
Tamir
Im from israel and the rebuild itself will cost me more then the transfer
That's a shame, where are you? There are rebuild kits available, might be a cheaper option. Ive got the 231 in my Jeep, its ok but you can't use 4x4 on hard surfaces.
Tamir
Does anyone knows if I can replace the transfer without the lever
Will it work is the difference is more than just the print
