Weird creaking noise passenger rear
marky38
michigan
2007 Liberty..I am now getting a weird creaking/grinding noise from the passenger rear area when braking moderately..it's quite noticable...the rear brake are pretty new....could a rotted frames cause this noise?...the frame on this is not too good in the rear control arm area..mabee I shock creaking in the back?..thanks!
marky38
michigan
Seems like this started after having it to the shop to get the front drive shaft removed..the noise could have been there before but nearly as bad..I could be mistaken too I really don't know
derekj
Powell River, BC
My guess would be you are hearing the control arm mount flexing due to the lack of metal around it.
That needs welding up ASAP, if the arm comes off it will end badly for someone.
