OldBlue
This may not apply to too many people, but I figured I do a write-up any way!
My '05 RME was lucky enough to come W/O fogs, and since I wanted a set, I had basically 2 options; install a set from a Renegade, or go the after market route. I choose the later.
Since there's no room in the budget at the moment for a set of PIAAs, I got these from my local Wally-World.
I wanted to set them into the grille instead of putting them on the bumper, so I needed a small diameter set. These are 2.5" in diameter, and I've got 3" inside of the grill.
To begin, I pulled the front grill off.
There's a nice flat lip that maked a great mounting location for the fogs.
I pulled the grill insert out...
...and put the grill back on so I could try a couple of different locations, but these looked the best to me.
Mark the location for the hole, and drill in 2 places.
It was pretty easy to get underneath the plastic support to tighten the nuts down, thanks to some cutouts in the support. I had to space the lights up about 3/4", so I used some fender washers and a couple of nuts.
The mounted lights!
Now, I had to cut the grill insert to clear the fogs. Measure 17 times, cut once!
Here's how the grill looked after putting the grill insert back into it.
My buddy gives it her approval!!
A close up of how the openings appear after trimming.
The final product, after soldering and heat-shrinking all the wiring!
I used a relay and tapped into the left running light, so the fogs are always on whenever the lights are on. The addition of a fuse should help avoid any problems!!
Here's a close-up of the clearances.
So far, I've had no heat-related problems in regards to the clearance between the lights and the grille. Hopefully, this'll help someone else in the same situation!
The mounted lights!
