Towing Hitch Question
JaySoy
Kansas City, Mo
Hello,
I had a quick question that someone might know. I found a trailer hitch at a local salvage yard for $70. It's on an '02. Will this fit my '04?
Thanks,
Jason
Check out where the hitch mounts to your Jeep. Sometimes(most of the time) the bolts that are welded inside of the frame get rusty and its hard to get the bolts in. Sometimes it requires a tap be ran through the hole.
Just a heads up. :)
BluPhant
Connecticut
The bolt directly above the muffler was a pain in the side for me. I ended up getting a set of box-ratchets (smaller than a standard ratchet wrench) to help with that one. With the right tools, it should be a 15-30 minute job. Took me ~2hrs.
hunter819
Western PA
Not to hijack or anything...
I found a hitch from an '02. That should also fit my '07 correct? Or did the changes include the rear mounts as well?
Thanks,
Hunter
BRASMAN
utah
