blacKJ
From what I've searched and have seen from crawling under the lib theres 4 sensors. 2 in bank one, both before the respective mini cats. 2 in bank 2, both after the mini cats. To my surprise no sensors near the main converter, especially after the cat. Now correct me if im wrong but a/f ratios are only set by the upstream sensors and are then adjusted based on downstream sensor input....so being the downstream sensors are only downstream from the mini cats then nothing in the system is actually checking efficiency of the main converter then besides obviously breaking precious emissions laws, running without the main cat technically shouldn't throw any codes for bad 02 sensors...?
