04 Libby Questions
When did those come out? Didn't see them on the site when I got the OME ones.
Been out for a while now, forget how long, was on my lst for the 04 but since its well on its way to...........not sure where??
They are going on the 03 , front and rear shocks will both be totally tuneable
quote from JBA site
JBA Total Control Valve Settings After extensive testing of the JBA Total Control cylinder, we baseline the settings at 4 clicks on compression and 12 clicks on rebound with the range up to 6 clicks on compression and 12 clicks on rebound. Up to 6 clicks on compression if you need a firmer ride or more suspension control. To Adjust the valves turn the knobs to the left or (-) till they stop then turn right or (+) to the desired settings JBA recommended setting 12 clicks on Rebound 4 clicks on Compression
mx3_ryder
troy VT
Sitting at 22.25 in front and 22 in rear on stock 235/70/16 tires
