KidsKJ02
- Joined
- Sep 15, 2023
- Messages
- 30
- Reaction score
- 20
I have an 02 limited in decent shape with a blown motor and rusted out 04 with a good motor, I’ve already pulled both motors and broke down the blown one. I was hoping this was a straight forward plug and play option but after much research I’m seeing I will have to change out the crankshaft reluctor ring and high side cam note from the 02 to the 04 to make the 02 ECM think it’s still running an 02, I see this to topick has been covered however, has anyone simply swapped out the computers instead as to not have to break down the running motor and remove the crank shaft to change out the reluctor ring? People talk about reprogramming the 02 ECM and all but I have the 04 ECM and everything else to go with it. Really don't want to tear down the good motor… thanks for any advice.
