swisely65
Hi all,
My '05 Liberty has around 91,000 miles. The check engine light came on, so I took it to the local dealership. This is their diagnosis:
CHECKED FOR DTC'S AND FOUND P0303 CYLINDER #3 MISFIRE. MONITORED LIVE MISFIRE DATA. FOUND #3 COUNTING ACTIVE MISFIRE EVENTS. SWAPPED IGNITION COIL AND SPARK PLUG. NO CHANGE. SCOPED #3 INJECTOR VOLTAGE WAVEFORM - LOOKS GOOD. CHECKED COMPRESSION - OK @ 170 PSI. CYLINDER LEAKDOWN SHOWED ONLY ABOUT 20% LEAKAGE. RUNNING COMPRESSION SLIGHTLY LOWER THAN #1 AND #5. THIS IS LIKELY A CYLINDER HEAD ISSUE. NEED TO REMOVE HEAD AND INSPECT CYLINDER HEAD COMPONENTS.
Shop says at least $2,700 to fix. I know nothing about mechanics.
Does this sound legit? Is that a fair price? Is there something simple they are overlooking? Does it make sense to put that kind of money into a Liberty with 91,000 miles? Is it likely the vehicle will be nickel and diming me to death from this point forward?
Any advice would be greatly appreciated. Thanks!
